script change user info dose not work
this script not work
in /ip hotspot user
i wold to change password when user have profile name “mm”
 :foreach i in [ /ip hotspot user find where disabled=no ]do={
  :if ([ :find [ /ip hotspot user get $i profile] ] = "mm" )do={
   [/ip hotspot user set $i password]="aaa"
where is the wrong ??
check this
/ip hotspot user
	:foreach i in=[find disabled=no] do={
		:local name [ get value-name=name $i]
			:local profile [get value-name=profile $i]
		:if ( $profile = "mm") do={set password=aaa $name}
The syntax error is you need spaces before the “do”. Also,
Doesn’t make sense. Setting the password is part of the command, and the command itself is the outermost, so it doesn’t need the “”, i.e.
/ip hotspot user set $i password="aaa"
What you want to do can be done in a much more simple and efficient fashion though:
/ip hotspot user set [find disabled=no && profile="mm"] password="aaa"
true code is :
:foreach i in [ /ip hotspot user find where disabled=no ] do={
:if ([ /ip hotspot user get $i profile] = "mm" ) do={
thank’s for all
