script change
The following script was working, and stopped recently (upgrade to v3.4 from a previous version):
/ip firewall nat remove [/ip firewall nat find src-address=$ipaddress]
I’m not a programming person. How do I fix this?
Travis
what is the complete script? to help you find the problem
That is the only line that does not work… it’s part of a Perl script on a Unix server.
you will need to post the complete script for anyone to be able to help you . copy and just paste whole thing from the first { to the last }
MT has not confirmed it yet, but general consensus is that they introduced some bugs in scripting with 3.4. If you rely on scripting I would recommend rolling back to 3.3 until 3.5 comes out.
-Louis
It doesn’t seem to work on 3.3 either… I had 3.1 on it before, and I think it was working then.
There has to be an easy fix… all I need is the
/ip firewall nat find src-address=1.2.3.4
to actually return the value of the entry it is associated with. I know for a fact it was working in 2.9.
All I am trying to do is remove a firewall rule based on the IP address that I supply. Help?
I am running 3.4 at my house.
I tested this snippet of code and it works as expected.
:local address 10.20.30.40
/ip firewall nat remove [/ip firewall nat find src-address="$address"]
You may want to double check your script again or post it to have it reviewed.
-Louis
