By mistake I have disabled default web 80 port and winbox 8219 port. I can not log In to Mikrotik hexlite router via web Interface or winbox. However I can log In using windows telnet.
Would you please help me to enable again winbox 8219 port using telnet command - what Is correct script for telnet command.
/ip service
set www address="" disabled=no port=80
set winbox address="" disabled=no port=8291
Telnet access?
Are you sure some hacker didnt telnet it and disabled your other access ;-PPP
I have just the thing for you!
https://forum.mikrotik.com/viewtopic.php?t=181718
Final comment, you should setup wireguard or some other VPN to provide remote in access to the router as well!
Thank you for help
I did both set /Ip service commands as per @rextended post, but still have an Issue with web Interface and winbox log In
winbox can not log In and reason Is connection refused
here what I get after /ip service print command
NAME PORT CERTIFICATE
0 telnet 23
1 ftp 21
2 I www 80
3 ssh 22
4 XI www-sl 443 none
5 api 8728
6 winbox 8291
7 api-ssl 8729 none
there Is a prefix Ignore for www service port 80 and prefix XI for www-sl
Is there a way to add another service Input for web Interface with different than 80 port , for example port 81
RouterOS version?
Provide an /export without publishing on forum serial number, email, username and password.
@rextended,
thank you for support
Router OS Is 6.34.2
winbox disappear after I changed settings In winbox 3.37 /ip firewall filter
current state Is
add action=reject chain=Input dst-port = 8291 protocol=tcp reject-with=\tcp-reset src-address-list=management
Would you please tell me correct script to remove that rejectin and set winbox dst-port 8291 to normal function
Why are you using such an old version of ROS? At least upgrade to 6.48.6 long term
After this
/ip firewall filter disable [find]
use winbox with “safe mode” button and enable again firewall rules except what block winbox, then upgrade to 6.48.6 and come back here with the export, and probably @anav can help you to make secure the device.
I will update firmware version
In order to get back to normal function winbox which current state Is
I have to execute following command
Is that correct
yes, but read all the previous post
I am trying
/ip firewall filter disable [find] and that don’t work
do I have to specify something In place of [find]
for example Is that correct
/ip firewall filter disable [add action=reject chain=Input dst-port = 8291 protocol=tcp reject-with=tcp-reset src-address-list=management]
here Is what I have In /ip firewall filter
add chain=input dst-port=22 protocol=tcp src-address-list=management
add chain=input dst-port=23 protocol=tcp src-address-list=management
add chain=input dst-port=2000 protocol=tcp src-address-list=management
add action=reject chain=input dst-port=8291 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=21 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=22 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=23 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=82 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=443 protocol=tcp reject-with=tcp-reset
add action=reject chain=input dst-port=8728 protocol=tcp reject-with=tcp-reset
no, is just
but after the command, you hit enter?
yes I hit enter
What are the results of
/ip firewall filter export
Paste this for be sure winbox is active on both IP and MAC modes:
/tool mac-server
set allowed-interface-list=all
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=yes
/ip service
I hope the syntax is not different on old 6.3x
I have only 6 minutes, and I must go away.
now every line Is disabled
add chain=input disabled=yes dst-port=22 protocol=tcp src-address-list=management
add chain=input disabled=yes dst-port=23 protocol=tcp src-address-list=management
add chain=input disabled=yes dst-port=2000 protocol=tcp src-address-list=management
add action=reject chain=input disabled=yes dst-port=8291 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=21 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=22 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=23 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=82 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=443 protocol=tcp reject-with=tcp-reset
add action=reject chain=input disabled=yes dst-port=8728 protocol=tcp reject-with=tcp-reset
that is a problem
Six minutes makes life easy when doing manual navigation and fixes…
If the original poster was running such an old version of ROS, he is also likely also running an ancient version of WinBox. I don’t remember which version it was, but at least one of the ROS updates a while back required a WinBox update. Make sure to be running a current version of WinBox. 3.37 is the current WinBox version and can be downloaded near the top of this page:
https://mikrotik.com/download
looks like /ip firewall filter disable [find]
disabled everythig In firewall filter list
