I see some changes in v6 break script compatibility from v5. One in particular is the new “/ip firewall connection tracking enable” option that’s gotten a new value of “auto”. Unfortunately this breaks scripts that treat the enabled property as a boolean. It now has to be treated as a string, for example:
# version 5
:if (![get enabled]) do={ :put "connection tracking disabled" }
# version 6
:if ([get enabled] != "yes") do={ :put "connection tracking disabled" }
Version 5 code fatally breaks on version 6, and version 6 code behaves incorrectly on version 5.
Can you come up with a better way of handling this new feature please?
Suggestion:
Add a new boolean property called “auto” and make it default to a value that makes the connection tracker behave as it did in version 5.
