Script disable route
Hello I need help I am new to mikrotik, it turns out that I have to make a script that reads the interface from time to time, check the rx if it is less than xxxmbps then it is presumed that there is no traffic, then run some pings to xxxx ip, at least 3 different ones , and if the 3 ips do not respond, deactivate the route, so that it can then ping again and if it responds, the reactivate (the route).
