Script disappears
I’m having an issue with my RB435G running 6.11. I add a simple script to the script list, when run the script it turns red in the list and the source goes away. All the script does is remove a file, fetches a config file (via http) and imports that file. The same script (and process) is working on several other devices, just not this one.
The only thing in the logs is “script removed by admin, new script added by admin, script removed from scheduler by admin, new script scheduled by admin”.
Almost seems like a filesystem issue since transferring files to it using winbox silently fails, and transferring files from it gives me an operation not permitted error. I’m not sure how to check the filesystem though.
Suggestions?
Thanks in advance!
