Script DNSHealth Can't send email
PROBLEM
OS 7.1rc6
  1. when I run the script nothing coming to my email.
    mikrotik log didn’t show any mail log
    Where my mistake?
    tq
STEPS TAKEN
  1. test manual email
    /tool e-mail set address=[:resolve smtp.gmail.com] from=user@gmail.com password
    =“-user” port=587 user=user@gmail.com tls=starttls
    /tool e-mail send to=user@gmail.com subject=“test” body=“test”
    I can receive the email
SCRIPT
https://github.com/arkashiks/dns_healthcheck/blob/master/dns_healthcheck.rsc
:local sysname [/system identity get name];
:local EMAIL "user@gmail.com";
:local PrimaryDNS "192.168.88.250";
:local BackupDNS "192.168.100.1";
:local TestDomain "mikrotik.com";
:local ConfiguredDNS [/ip dns get servers];
###### when router is in its primary configuration
:if ($PrimaryDNS = $ConfiguredDNS) do={
    :do {
        ###### test resolution
        :put [:resolve $TestDomain server $ConfiguredDNS];
        ###### generate syslog messages
        /log info "Primary DNS $PrimaryDNS healthcheck completed, no issues";
    } on-error={
        :put "resolver failed";
        /log info "name resolution using primary DNS $PrimaryDNS failed";
        /log info "temporary setting backup DNS $BackupDNS as primary";
        ###### update DNS with backup DNS
        /ip dns set servers=$BackupDNS;
        ###### send notification email
        /tool e-mail send to="$EMAIL" subject="$sysname script notification: Primary DNS $PrimaryDNS down" body="Primary DNS $PrimaryDNS is down.\r\nDNS configuration changed to backup DNS $BackupDNS."
        /log info "notification email to $EMAIL sent";
###### when router is in its backup configuration
:if ($BackupDNS = $ConfiguredDNS) do={
    :do {
        :put [:resolve $TestDomain server $PrimaryDNS]
        /log info "name resolution using primary DNS $PrimaryDNS working now";
        /log info "restoring original DNS configuration";
        ###### revert back DNS configuration to original
        /ip dns set servers=$PrimaryDNS;
        /tool e-mail send to="$EMAIL" subject="$sysname script notification: Primary DNS $PrimaryDNS up" body="Primary DNS $PrimaryDNS is up.\r\nOriginal DNS configuration restored."
    } on-error={
        /log info "system is configured with backup DNS $BackupDNS";
        /log info "Primary DNS $PrimaryDNS is still down, next check in 300 seconds";
Do always use code tag button above post for posting codes.
[size=200]</>[/size]
This script will only send email when DNS has changed, so if no change, no DNS.
Try change:
 /tool e-mail send to="$Email" subject="$sysname script notification: Primary DNS $PrimaryDNS down" body="Primary DNS $PrimaryDNS is down.\r\nDNS configuration changed to backup DNS $BackupDNS."
to:
:put "Primary DNS $PrimaryDNS is down."
Change this:
to some that does not work (to force change), eks:
:local TestDomain "xxxyyy333.com"
Wrap the whole script in extra curly brackets. {}, then cut and past it to terminal.
If script then show message “Primary DNS $PrimaryDNS is down.”, you know script does work.
Change DNS back to original, replay put line with /tools e-mail and test again.
