Script doesn't continue after a statement [SOLVED]
i’ve this script.
The script works fine!
But…
after :foreach {…} statement it doesn’t execute nothing other!
For example a /log info “…” doesn’t works, or a command, or an IF statement… Nothing works after } of the :foreach statement.
I can’t realize what is blocking!
I tried to add { at begin of the script and } to close at the end but nothing.
This is script:
:global currentBuf [ :toarray [ /log find where (message~"logged" || message~"login") ] ] ;
:global currentLineCount [ :len $currentBuf ] ;
:global currentTime [ :totime [/log get [ :pick $currentBuf ($currentLineCount - 1) ] time ] ];
:global messageTime;
:global interv [ /system scheduler get [find name="Test"] interval ] ;
:global message "";
:global diff ($currentTime - $interv);
:foreach i in=[$currentBuf] do={
  :set messageTime [/log get [ :pick $currentBuf ($currentLineCount - 1) ] time];
  :if ( $messageTime >= $diff ) do={
    :set message [/log get [ :pick $currentBuf ($currentLineCount - 1) ] message];
    /log info "test this"
  :set currentLineCount ($currentLineCount - 1);
Thanks all.
Maybe, use :log info " " instead of /log info " "
You confused the actual logging and the log menu itself at this line:
Hi msatter thank you,
actually I can also remove the instruction “log…” or doing nothing, but the problem remains.
I found!
Sorry!!!
damn!!!
the line offending is:
  :set messageTime [/log get [ :pick $currentBuf ($currentLineCount - 1) ] time] ;
if i comment that it works!
so, the solution is to add ad this line :totime !!!
So, the line, finally, looks like this:
 :set messageTime [ :totime [/log get [ :pick $currentBuf ($currentLineCount - 1) ] time] ];
I change in SOLVED!
Thank yoy very much!!!
…3 days i searching an explanation!!!
If you do not need the value utside the script and store it for later user, change from global to local variable:
Semicolon are not needed at the end of the line anymore, only if you have more than one command at same line.
So change to this:
:local currentBuf [ :toarray [ /log find where (message~"logged" || message~"login") ] ]
If you do like to examine logs in a external program , have a look at Splunk. See link in my signature.
Good that you managed to solve it yourself. I tested
/log info "test"
and it worked. I never use that and use :log because you can call it wherever you are in ROS. I :log very often to debug my code and I use it as flags to see which line is buggy and if I get the correct values in the variables.
ok, thank you very much! :slight_smile:
