Script Error not enough permissions (9)
I’m trying to run a script this script:
/port remove [find inactive];
/port set numbers=1 name=test
and I get this error:
I’m the admin of the router , have all the permissions
NAME GROUP ADDRESS LAST-LOGGED-IN
0 ;;; system default user
admin full jul/23/2014 13:41:42
2 name=“full” policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,
password,web,sniff,sensitive,api
I’m using RB411 V6.10
Thanks ,
First of all, disable the console/service using that port!
no one is using the inactive port , that why I want to remove it.
but I took what you said and put delay between the commands and now it working.
delay 2;
/port set numbers=1 name=test;
so this is O.K. , right?
If is working, yes :astonished:
Thanks ,
