Script Example for Limiting The Time An IP Address Can Be Used
I am new to the MikroTik Router OS.
I have searched several boards for the answer in which I am searching for but haven’t found quite what I need.
What I am trying to do is write a script that will allow me to limit the time that a certain IP address can be used.
Such as … I want an IP address (or mac address if that is easier to control) be only be able to be logged into by a users device from 10am to say 7pm for example.
Can anyone point me to an example of a script that I can use to write my own script for such a situation?
Thank you in advance. If there is a script that I missed during one of my searches I apologize for the duplication of questions in advance.
Thank you…
Hi , it could be done with scripting , but it would be much easier with IP firewall , just drop any packet from specific users in specific date and time ! also there are a lot of features you may interested to use :wink:
you should know if your user changes his or her ip address it won’t work anymore and could easily bypass your firewall rules , unless your firewall has been configured correctly for this situation , if you wanna use and control over MAC addresses , you can use bridge firewalling
