Script failing after running for a while
Hello!
I am running a script on boot that is an infinite loop. For some reason the script stops running after a while (it no long is listed as a job) - maybe around 30 minutes to an hour after being up. Can someone help me see what’s going on? BTW this used to work great before.
I am running version 6.42.1 on a RB2011UAS-2HnD
:local conn [/ip firewall mangle find comment="LoL connetion mark as gaming"];
:local connvoip [/ip firewall mangle find comment="voip-in packet mark RTP"];
:local count1 [/ip firewall mangle get value-name=packets $conn ];
:local count1voip [/ip firewall mangle get value-name=packets $connvoip ];
:local count2 [/ip firewall mangle get value-name=packets $conn ];
:local count2voip [/ip firewall mangle get value-name=packets $connvoip ];
:local wait 2;
#:local rate ((($count2 + $count2voip) - ($count1 + $count1voip)) / $wait );
:local status;
:set status [ /queue tree get in disabled ];
:local status2;
:set status2 [ /queue tree get out disabled ];
:while ( ((($count2 + $count2voip) - ($count1 + $count1voip)) / $wait ) <= 5 ) do={
:set count1 [/ip firewall mangle get value-name=packets $conn ];
:set count1voip [/ip firewall mangle get value-name=packets $connvoip ];
:delay $wait;
:set count2 [/ip firewall mangle get value-name=packets $conn ];
:set count2voip [/ip firewall mangle get value-name=packets $connvoip ];
:put ((($count2 + $count2voip) - ($count1 + $count1voip)) / $wait );
:while ( ((($count2 + $count2voip) - ($count1 + $count1voip)) / $wait ) > 5 ) do={
:if ($status || $status2 = true) do={
/queue tree enable in;
/queue tree enable out;
:set status false;
:set status2 false;
:log info "Queue Activated";
:delay $wait;
:delay $wait;
:if ($status = false ) do={
/queue tree disable in;
/queue tree disable out;
:set status true;
:set status2 true;
:log info "Queue Deactivated";
