valent
1
Hi, can you please help me.
We have s missbehaveing adsl router in out network, which for some or other reason stops working.
So we need a script which does the following:
ping some external site (http://www.google.com) if 5 pings drop login via telnet to adsl router and issue “reboot” command.
or
every 6 hours login via telnet to adsl router and issue “reboot” command
Thank you.
Eugene
2
no way to do this in RouterOS.
valent
3
Ah, then we will do it form a linux box on the network.
I think it should be possible. Something like:
:local i 0; {:do {:set i ($i + 1)} while (($i < 5) && ([/ping 64.77.90.2 interval=3 count=1]=0)}; :if ($i=5) do={/system telnet… }
That would ping the IP address 5 times and if all 5 pings time out you could issue any arbitary commands.
Eugene
5
/system telnet works only in interactive mode.
Then indeed it would not work!
