Script for limiting user on total traffic quota
the script described here:
http://wiki.mikrotik.com/wiki/Limiting_a_user_to_a_given_amount_of_traffic_II
:local traf;
/queue simple
  :for i from=1 to= 254 do =  {
    :if ([/queue simple find target-addresses=("192.168.1." . $i)] != "") do={
      :set traf [get [find target-addresses=("192.168.1." . $i)] total-bytes]
      :if ($traf  > 104857600) do = {
        set [find target-addresses=("192.168.1." . $i)] max-limit= 32000/64000
does not work anymore
Because this script is very old, what would be the correct syntax for it to work in ROS V6.x?
I solved
it works now in ROS v6.x
:local traf;
/queue simple
:for i from=1 to=254 do={
:if ([/queue simple find target=("192.168.1." . $i . "/32")]!="") do={
:set traf [get [find target=("192.168.1." . $i . "/32")] total-bytes]
:if ($traf>104857600) do={
set [find target=("192.168.1." . $i . "/32")] max-limit=80000/80000
Does the script assume the simple queues already exist ?
