Hi Scripting Gurus,
i really need your help.
I need to log the “Distance” value that shows in the wireless interface Status page in winbox when it goes over a pre threshold value eg: 4km.
i only need the one overall value in the status page, i dont need each individual clients values
karma waiting to be awarded.
many thanks in advance
You can see the distance only of the NV2 connections!
Syntax for 6.7+
:local tmpDistance value=0;
:local isOver value=0;
:foreach i in=[/interface wireless registration-table find] do={
:set $tmpDistance value=[/interface wireless registration-table get value-name=distance $i];
:if (($tmpDistance + 0) > 4) do={ :set $isOver value=1; };
You can put all controls you want in the script.
At the end of the cycle, if one value are > of 4km, the variable isOver are = 1
Hi in winbox
wireless - Interfaces - Wlan1 - Status
Also, if this
[:len [/interface wireless registration-table find where distance>4]]
are > 0, then one or more are at distance > 4
eheheheh…
The previous script, are the base for logging, display the longest distance, etc.
yes thank you but i think this checks every client right?
Yes, and again I made a post before your reply
read my previous post
explain better this for who read this topic:
:local test value=[:len [/interface wireless registration-table find where distance>4]];
if test > 0 one or more client are connected with distance > 4
karina
11
hi,
thats great thanks, I can work with this karma on way
I’m happy because I have understand your needs.
By.
