hi to all.
i try a script for ping about 30 customers for test ping and bandwith. Anyone help me?
nothing can help me?
Describe in details what exactly you want to do with this script.
i want to use ping speed to test my bandwith on my customers without i ping one to one customers. For example i want to ping and interval from x.x.x.1 to x.x.x.254
You will not be able to use ping-speed from script properly. Instead you should use bandwidth-test.
Run a for loop in which bandwidth-test is executed with specified interval value.
yes ok i read another topic of bandwidth-test, but in my mikrotik dont work. I use the last version
Post your script here
i don’t have script. I search a script
So how do you know that script isn’t working if you don’t have a script ![]()
i search a script if anyone have it
