Script for Version 7.15.1 ( Open VPN )
i created a script for open vpn server
once finished i need to call the export button with the certification located in the file folder
i didn’t find the exact command for the export button located in open vpn server
also i need to know the firewall rule to use in order to allow the open vpn users to access the lan network
thanks
 /interface ovpn-server server export-client-configuration
thanks bro it worked with the script
but now i can access the open vpn but cant access the lan-network
please check below the script for my open vpn :
/certificate
add name=CA common-name=CA days-valid=3650 key-usage=key-cert-sign,crl-sign
sign CA ca-crl-host=184.142.40.170
:delay 5
set CA trusted=yes
/certificate
add name=server common-name=server days-valid=3650 key-usage=digital-signature,tls-server,key-encipherment
sign server ca=CA
:delay 5
set server trusted=yes
/certificate
add name=client common-name=client days-valid=3650 key-usage=tls-client
sign client ca=CA
:delay 5
export-certificate CA file-name=CA
export-certificate client export-passphrase=12345678 file-name=client
:delay 5
/ip/pool add name=openvpn range=10.10.5.2-10.10.5.20
:delay 2
/ppp profile add name=ovpn local-address=10.10.5.1 remote-address=openvpn
:delay 2
/ppp secret add name=ants password=P@ssw0rd profile=ovpn
:delay 2
/interface ovpn-server server set enabled=yes certificate=server default-profile=ovpn
:delay 2
/interface ovpn-server server export-client-configuration server-address=194.126.17.238 ca-certificate=CA.crt clie
nt-certificate=client.crt client-cert-key=client.key
I didn’t understand, elaborate, please. It would be great if you could export your config and share it.
/export hide-sensitive ters
