Script function for converting and shifting the standard date to OS Mikrotik
Script function for converting and shifting the standard date to OS MikroTik
Start variables:
  • First mandatory variable in “aug/22/2021” or “08/22/2021” format.
  • Second optional variable in -5 or 0 or 5 format. Specifies how many days forward or backward you want to move the total date as a result.
  • Third optional variable in true or false format. The value of the “true” variable prevents you from changing the format of the month from text to number and from number to text.
:global FuncDateConvert do={
:local LocalDate $1
:local ChangeDay $2
:local NoConvertMonth $3
:local Day [:pick $LocalDate ([:find $LocalDate "/" -1] + 1) [:find $LocalDate "/" [:find $LocalDate "/" -1]]]
:local Month [:pick $LocalDate -1 [:find $LocalDate "/" -1]]
:local Year [:pick $LocalDate ([:find $LocalDate "/" [:find $LocalDate "/" -1]] + 1) [:len $LocalDate]]
:local ArrayMonth {"jan";"feb";"mar";"apr";"may";"jun";"jul";"aug";"sep";"oct";"nov";"dec"}
:local ArrayMonthDay {31;28;31;30;31;30;31;31;30;31;30;31}
:local MonthType "str"
# Check the input format and correct if necessary.
:if ( [:typeof $NoConvertMonth] = "nothing") do={:set  $NoConvertMonth "false"}
:if ( [:typeof $ChangeDay] = "nothing") do={:set  $ChangeDay 0}
:if ( [:typeof $ChangeDay] = "str") do={:set  $ChangeDay [:tonum $ChangeDay]}
:if ( [:typeof $Day] = "str") do={:set  $Day [:tonum $Day]}
:if ( [:typeof $Year] = "str") do={:set  $Year [:tonum $Year]}
# Check the data format of the Month variable and correct if necessary.
:if ( $Month~"^[0-9]{1,2}\$") do={
	:set  $Month [:tonum $Month]
	:set  $MonthType "num"
# Calculate the numerical equivalent for the Month variable
:if ($MonthType = "str") do={
	:foreach MonthNum,MonthStr in=$ArrayMonth do={
		:if ($MonthStr = $Month) do={:set $Month ($MonthNum + 1)}
# Calculate date shift by specified number of days
:if ($ChangeDay > 0) do={
	:set $Day ($Day + $ChangeDay)
		:while ((($Day > ($ArrayMonthDay->($Month - 1))) and ((($Year % 4) != 0) or ((($Year % 4) = 0) and ($Month != 2)))) or \
		(($Day > (($ArrayMonthDay->($Month - 1)) + 1)) and ($Month = 2) and (($Year % 4) = 0))) do={
		:if (($Month = 2) and (($Year % 4) = 0)) do={:set $Day ($Day - (($ArrayMonthDay->($Month - 1)) + 1))
		} else={:set $Day ($Day - ($ArrayMonthDay->($Month - 1)))}
		:set $Month ($Month + 1)
		:if ($Month > 12) do={:set $Year ($Year + 1); :set $Month 1}
:if ($ChangeDay < 0) do={
	:set $Day ($Day + $ChangeDay )
	:while ($Day < 1) do={
		:set $Month ($Month - 1)
		:if ($Month < 1) do={:set $Year ($Year - 1); :set $Month 12}
		:if (($Month = 2) and (($Year % 4) = 0)) do={:set $Day ($Day + (($ArrayMonthDay->($Month - 1)) + 1))
		} else={:set $Day ($Day + ($ArrayMonthDay->($Month - 1)))}
# Add the character 0 to the beginning of the Day variable
:if (($Day < 10) and ([:len $Day] < 2))  do={:set $Day ("0".$Day)}
# Calculate the text equivalent for the Month variable
:if (($MonthType = "num") and ($NoConvertMonth = "false")) do={:set $Month ($ArrayMonth->($Month - 1))}
# Add the character 0 to the beginning of the Month variable
:if (($MonthType = "num") and ($NoConvertMonth = "true") and ($Month < 10)) do={:set $Month ("0".$Month)}
:if (($MonthType = "str") and ($NoConvertMonth = "true")) do={:set $Month ($ArrayMonth->($Month - 1))}
:if (($MonthType = "str") and ($NoConvertMonth = "false") and ($Month < 10)) do={:set $Month ("0".$Month)}
# Return data array in MM/DD/YYYY, DD, MM, YYYY format
:return {($Month."/".$Day."/".$Year);$Day;$Month;$Year}
Example of execution:
:put "Start date 01/01/2021"
:put ([$FuncDateConvert "01/01/2021" -1 true]->0)
:put ([$FuncDateConvert "01/01/2021" -30 true]->0)
:put ([$FuncDateConvert "01/01/2021" -31 true]->0)
:put ([$FuncDateConvert "01/01/2021" -32 true]->0)
:put ([$FuncDateConvert "01/01/2021" 1 true]->0)
:put ([$FuncDateConvert "01/01/2021" 20 true]->0)
:put ([$FuncDateConvert "01/01/2021" 31 true]->0)
:put ([$FuncDateConvert "01/01/2021" 32 true]->0)
:put "Start date 11/01/2021"
:put ([$FuncDateConvert "11/01/2021" 1 true]->0)
:put ([$FuncDateConvert "11/01/2021" 20 true]->0)
:put ([$FuncDateConvert "11/01/2021" 31 true]->0)
:put ([$FuncDateConvert "11/01/2021" 32 true]->0)
:put ([$FuncDateConvert "11/01/2021" 61 true]->0)
:put ([$FuncDateConvert "11/01/2021" 62 true]->0)
:put ([$FuncDateConvert "11/01/2021" 91 true]->0)
:put ([$FuncDateConvert "11/01/2021" 92 true]->0)
12/31/2020
12/02/2020
12/01/2020
11/30/2020
01/02/2021
01/21/2021
02/01/2021
02/02/2021
11/02/2021
11/21/2021
12/02/2021
12/03/2021
01/01/2022
01/02/2022
01/31/2022
02/01/2022
:put ([$FuncDateConvert "01/01/2021" -1 ]->0)
:put ([$FuncDateConvert "01/01/2021" -30 ]->0)
:put ([$FuncDateConvert "01/01/2021" -31 ]->0)
:put ([$FuncDateConvert "01/01/2021" -32 ]->0)
:put ([$FuncDateConvert "01/01/2021" 1 ]->0)
:put ([$FuncDateConvert "01/01/2021" 20 ]->0)
:put ([$FuncDateConvert "01/01/2021" 31 ]->0)
:put ([$FuncDateConvert "01/01/2021" 32 ]->0)
:put ([$FuncDateConvert "11/01/2021" 1 ]->0)
:put ([$FuncDateConvert "11/01/2021" 20 ]->0)
:put ([$FuncDateConvert "11/01/2021" 31 ]->0)
:put ([$FuncDateConvert "11/01/2021" 32 ]->0)
:put ([$FuncDateConvert "11/01/2021" 61 ]->0)
:put ([$FuncDateConvert "11/01/2021" 62 ]->0)
:put ([$FuncDateConvert "11/01/2021" 91 ]->0)
:put ([$FuncDateConvert "11/01/2021" 92 ]->0)
dec/31/2020
dec/02/2020
dec/01/2020
nov/30/2020
jan/02/2021
jan/21/2021
feb/01/2021
feb/02/2021
nov/02/2021
nov/21/2021
dec/02/2021
dec/03/2021
jan/01/2022
jan/02/2022
jan/31/2022
feb/01/2022
:put ([$FuncDateConvert "jan/01/2021" -1 ]->0)
:put ([$FuncDateConvert "jan/01/2021" -30 ]->0)
:put ([$FuncDateConvert "jan/01/2021" -31 ]->0)
:put ([$FuncDateConvert "jan/01/2021" -32 ]->0)
:put ([$FuncDateConvert "jan/01/2021" 1 ]->0)
:put ([$FuncDateConvert "jan/01/2021" 20 ]->0)
:put ([$FuncDateConvert "jan/01/2021" 31 ]->0)
:put ([$FuncDateConvert "jan/01/2021" 32 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 1 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 20 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 31 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 32 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 61 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 62 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 91 ]->0)
:put ([$FuncDateConvert "nov/01/2021" 92 ]->0)
12/31/2020
12/02/2020
12/01/2020
11/30/2020
01/02/2021
01/21/2021
02/01/2021
02/02/2021
11/02/2021
11/21/2021
12/02/2021
12/03/2021
01/01/2022
01/02/2022
01/31/2022
02/01/2022
All occurencies of this type are wrong (for example):
:set $VarName
must be writed:
:set VarName
The script do not consider the 29 feb and everytime you add or remove days, if the operation walk over a 29 feb, obviously do wrong results.
[rextended@AP Matrix] > :put ([$FuncDateConvert "feb/29/2024" 1]->0)
03/2/2024
[rextended@AP Matrix] > :put ([$FuncDateConvert "feb/29/2024" -1]->0)
01/2/2024
Also do that strange…
[rextended@AP Matrix] > :put ([$FuncDateConvert "jan/01/2024" -10]->0)
01/11/2024
I suggest you to do more tests, indenting the scripts also help…
Calculation of a high year, when in February + 1 day did not realize due to the lack of technical work with fractions. This is an error in operation.
If you have a technical solution, please describe it.
Fixed error with date reduction:
:put ([$FuncDateConvert “jan/01/2024” -10]->0)
12/22/2023
:put ([$FuncDateConvert “jan/01/2024” -25]->0)
12/07/2023
Fixed the return value of the Day variable if it is less than 10. Appends 0 before the number.
Thank you for the feedback. Waiting for feedback.
Old:
:if ($Day > ($ArrayMonthDay->($Month-1))) do={
:set $Day ($Day - ($ArrayMonthDay->($Month-1)))
New:
:set $Day ($Day + ($ArrayMonthDay->($Month-1)))
Why use fraction?
ignoring century and other complex rules for feb 29 (if we are alive on 2100 we fix that),
simpy 2021 % 4 = 1 … only if reminder is 0 the year have feb 29 day
Thank you for your thought.
Corrections have been scripted.
Fixed:
:while ((($Day > ($ArrayMonthDay->($Month-1))) and ((($Year%4)!=0) or ((($Year%4)=0) and ($Month!=2)))) or (($Day > (($ArrayMonthDay->($Month-1))+1)) and ($Month=2) and (($Year%4)=0))) do={
:if (($Month=2) and (($Year%4)=0)) do={:set $Day ($Day - (($ArrayMonthDay->($Month-1))+1))} else={:set $Day ($Day - ($ArrayMonthDay->($Month-1)))}
:if (($Month=2) and (($Year%4)=0)) do={:set $Day ($Day + (($ArrayMonthDay->($Month-1))+1))} else={:set $Day ($Day + ($ArrayMonthDay->($Month-1)))}
Some hint:
International / ISO8601 date: 2021-08-23
accept “today” parameter, instead of date, for use current date obtained from routeros
Good afternoon.
Do you propose to change the date output and execute it in ISO format?
You can generate a date in any format from the output array of the function.
My goal with this feature is to convert an array that contains the dates when the files were created. In the future, sort by ascending based on the Date field and delete obsolete files.
There is a script that generates backup files in the "backup" + "rsc" formats and sends to mail.
inside routeros filesystem?
It is. There is a need to clean the MikroTik OS file system according to certain criteria.
Developers of MikroTik OS did not take care of the functionality of converting and comparing this in the format "Date."
You accept some hint?
I don’t understand your thought. Try explaining more openly.
If you check the .id, the file on same folder are indexed on creation time, but on creation-time appear LAST MODIFIED time…
/file> :put [print as-value]
.id=*1f0001a6;creation-time=jan/02/1970 02:00:38;name=flash/pub;type=directory;
.id=*1f0001a7;creation-time=jan/02/1970 02:00:38;name=flash/firmware;type=directory;
.id=*1f0001a8;creation-time=jan/02/1970 02:00:38;name=flash/hotspot;type=directory;
.id=*1f0001a9;creation-time=jan/02/1970 02:00:38;name=flash/log;type=directory;
.id=*1f0001aa;creation-time=jan/02/1970 02:00:38;name=flash/package;type=directory;
.id=*1f0001ab;creation-time=jan/02/1970 02:00:38;name=flash/pcap;type=directory;
.id=*1f0001ac;creation-time=jan/02/1970 02:00:38;name=flash/skins;type=directory;
.id=*1f0001ad;creation-time=jan/02/1970 02:00:38;name=flash/web-proxy;type=directory;
.id=*1f0001d7;creation-time=jan/02/1970 02:00:39;name=flash/webproxy;type=directory;
.id=*1f0001d8;creation-time=jan/02/1970 02:00:39;name=flash/webproxy/error.html;size=529;type=.html file;
.id=*1f000205;creation-time=jan/01/1970 02:00:06;name=flash;type=disk;
.id=*1f000213;creation-time=aug/20/2021 12:21:20;name=flash/log/log.0.txt;size=1496;type=.txt file;
.id=*1f000295;creation-time=jan/08/2008 17:15:17;name=flash/Script_CBM.txt;size=39;type=.txt file;
.id=*1f0002b3;creation-time=jan/08/2008 17:15:17;name=flash/Script_CBM.backup;size=21979;type=backup;
.id=*1f0002f1;creation-time=jun/24/2021 16:45:36;name=flash/skins/default.json;size=4;type=.json file
On the previous question:
Do you suggest accepting a date in a different format for processing?
Do you suggest displaying in a different format?
Do you want to add an incoming parameter to correctly read the date in the ISO8601 format?
As for the date the files were created, thank you for specifying. In my case, it's not a problem. Files are created on a schedule and are not modified. So for a particular set of files, I can rotate files.
file print where name~"^$[/system identity get name]-[0-9]{8}-[0-9]{4}\\.(backup|rsc)\$"
 # NAME                                                           TYPE        SIZE CREATION-TIME
 0 MikroTik DC_Cheap Border-20200720-1655.backup                  backup                                                          214.2KiB jul/20/2020 16:55:12
 1 MikroTik DC_Cheap Border-20200721-0607.backup                  backup                                                          209.0KiB jul/21/2020 06:07:29
 2 MikroTik DC_Cheap Border-20200721-0710.backup                  backup                                                          198.0KiB jul/21/2020 07:10:57
 3 MikroTik DC_Cheap Border-20201111-1305.backup                  backup                                                          209.9KiB nov/11/2020 13:05:50
 4 MikroTik DC_Cheap Border-20201118-1345.backup                  backup                                                          212.7KiB nov/18/2020 13:45:30
 5 MikroTik DC_Cheap Border-20201121-1637.backup                  backup                                                          215.4KiB nov/21/2020 16:37:57
 6 MikroTik DC_Cheap Border-20201122-1011.backup                  backup                                                          215.4KiB nov/22/2020 10:11:52
 7 MikroTik DC_Cheap Border-20201207-1707.backup                  backup                                                          212.3KiB dec/07/2020 17:07:45
 8 MikroTik DC_Cheap Border-20201224-0545.backup                  backup                                                          212.7KiB dec/24/2020 05:45:03
 9 MikroTik DC_Cheap Border-20201224-0643.backup                  backup                                                          212.7KiB dec/24/2020 06:43:06
10 MikroTik DC_Cheap Border-20201228-0752.backup                  backup                                                          212.7KiB dec/28/2020 07:52:36
11 MikroTik DC_Cheap Border-20201228-1102.backup                  backup                                                          212.7KiB dec/28/2020 11:02:47
12 MikroTik DC_Cheap Border-20210115-1119.backup                  backup                                                          214.6KiB jan/15/2021 11:19:28
13 MikroTik DC_Cheap Border-20210118-1358.backup                  backup                                                          212.5KiB jan/18/2021 13:58:55
14 MikroTik DC_Cheap Border-20210119-0723.backup                  backup                                                          213.3KiB jan/19/2021 07:23:19
15 MikroTik DC_Cheap Border-20210122-0629.backup                  backup                                                          213.5KiB jan/22/2021 06:29:12
16 MikroTik DC_Cheap Border-20210301-1506.backup                  backup                                                          348.0KiB mar/01/2021 15:06:15
17 MikroTik DC_Cheap Border-20210314-0840.backup                  backup                                                          366.8KiB mar/14/2021 08:40:34
18 MikroTik DC_Cheap Border-20210527-0926.backup                  backup                                                          698.2KiB may/27/2021 09:26:37
19 MikroTik DC_Cheap Border-20210607-1701.backup                  backup                                                          704.8KiB jun/07/2021 17:01:52
20 MikroTik DC_Cheap Border-20210710-1315.backup                  backup                                                          721.3KiB jul/10/2021 13:15:00
21 MikroTik DC_Cheap Border-20210710-1315.rsc                     script                                                          324.2KiB jul/10/2021 13:15:04
22 MikroTik DC_Cheap Border-20210717-0100.backup                  backup                                                          723.5KiB jul/17/2021 01:00:00
23 MikroTik DC_Cheap Border-20210717-0100.rsc                     script                                                          325.4KiB jul/17/2021 01:00:03
24 MikroTik DC_Cheap Border-20210724-0100.backup                  backup                                                          725.8KiB jul/24/2021 01:00:00
25 MikroTik DC_Cheap Border-20210724-0100.rsc                     script                                                          326.6KiB jul/24/2021 01:00:03
26 MikroTik DC_Cheap Border-20210731-0100.backup                  backup                                                          740.2KiB jul/31/2021 01:00:00
27 MikroTik DC_Cheap Border-20210731-0100.rsc                     script                                                          334.4KiB jul/31/2021 01:00:04
28 MikroTik DC_Cheap Border-20210814-0100.backup                  backup                                                          255.2KiB aug/14/2021 01:00:00
29 MikroTik DC_Cheap Border-20210814-0100.rsc                     script                                                           70.3KiB aug/14/2021 01:00:02
30 MikroTik DC_Cheap Border-20210821-0100.backup                  backup                                                          262.4KiB aug/21/2021 01:00:00
31 MikroTik DC_Cheap Border-20210821-0100.rsc                     script                                                           74.4KiB aug/21/2021 01:00:02
I think if you have already the date on ISO8601 like 20210823 format on filename, is useless check time.
For example, if you do backup every week (but is better to do not leave inside but do it by mail or on another device)
on the script delete the file than have inside two month ago.
One moment I write one thing…
Honestly, I'll tell you.
I had no desire to forge file names. Process the creation and modification date of the object faster than extracting the date from the file name. And I want a kind of universality.
That's what you think. Files are sent to email mail. And here there is a desire to organize file rotation.
For example something like:
:local month <from your function actual month - 2>
:local id [/system identity get name]
/file remove [find where name~“^$id-[0-9]{4}$month[0-9]{2}-[0-9]{4}\.(backup|rsc)$”]
Once you set 1st time the directory clean, automatically delete 3 monts old backup
A good and simple solution that I discarded because all files will be deleted for the specified month. You can stay with one single backup file in the new month. Of course there are backup files in the mail.
In my opinion, the best solution will be to compare the entire date without time.
Your example of deleting files simplified what I wanted to do. Thank you.
Really… not… Delete the backup of 2 months ago, previous month and actual month are untouched…
Always happy to help and give hints, thanks!
You're welcome.
I hope my script came to your liking and will be useful to others.
I'll post another script as soon as I'm ready.
I am very happy every time someone shares something new.
I saw some interesting potential from your script,
otherwise I would not have tried to suggest things to you,
and certainly in the future you will come up with a solution to something else,
thanks to what you made me think today.
Really thanks for that.
Another hint, regexp matching 1 to 12 and 01 to 09:
^([0]?[1-9]|1[0-2])\$
matches
if there is present 0 or not followed by a number from 1 to 9
OR
by a 1 followed by a number from 0 to 2
Remember to add \ before ? on terminal, on script do not put the \ before ?
The only things I have to say now, is: please format the script or is hard to understand :slight_smile:
