Script help
I’m stuck.
This works:
:if ([/interface get [/interface find name=“VPN”] running] = false) do={
/log info Test
This doesn’t work:
/tool e-mail send to=email@address.com subject=“SUBJECT” body=“BODY”
But this command works on it’s own:
I have no idea. Any one see the issue? Or is there a better way to do this? I got this example from another forum post.
Thank you
Permissions of script maybe?
Don’t think so. Similar scripts with the email part work fine with the same permissions.
I tried this again from scratch entering it manually into the terminal to test it. Now it works. Must have been a formatting issue. Thanks
