Script in mikrotik to Login into public hotspot captive portal
i have a public hotspot captive portal that i want login automatically using my mikrotik router, the ideia is by cronjob or something perform a form post with the credencials to login into that public hotspot, then the mikrotik router will work as a gateway to provide internet acess to the network without the need for other pc´s perform the same login. anyone have done something like that?
thanks Jaso
Search for:
/system schedule
/tool fetch
Enviado de meu SM-G800H usando Tapatalk
