script log mail usb [SOLVED]
Hi, I’m creating this script runs monthly. If it finds the USB stick, save the file in the correct path. if the USB stick is not present, the $usbState status does not appear, therefore no errors appear but the path does not change and the email does not proceed. dove am I wrong?
:local NameHotspot "Green Hotspot"
:global email
:local LastRun [:pick ([/system script get [find name="$NameScript"] value-name=last-started]) 0 7];
:local date [:pick ([/system clock get date]) 0 7];
:local year [:pick $date 0 4]
:local month [:pick ([/system clock get date]) 5 7];
:local LastMonth ($month - 1)
:if ([:len $LastMonth] = 1)  do={
    :set $LastMonth ("0".$LastMonth)
:local LastPeriod ($year."-".$LastMonth)
:local LastFile ($LastPeriod."-hs.log")
:put $LastRun
:put $date
:put $month
:put $LastMonth
:put $LastPeriod
:put $LastFile
/file
:foreach item in=[find where name~"usb" and type=disk] do={
:local usbName [get $item name]
:put $usbName
:local usbState
:if ([:len $usbName] > 0) do={
    :set usbState "true"
    } else={
    :set usbState "false"
:put $usbState
:if ($LastRun != $date) do={
    :if ($usbState = "true")  do={
        /system logging action set [find name="hslog"] disk-file-name="$usbName/$date.hs.log"
        } else={
        /system logging action set [find name="hslog"] disk-file-name="$date.hs.log"
        /tool e-mail send to=$email from=[/tool e-mail get value-name=from] server=[/tool e-mail get value-name=server] port=[/tool e-mail get value-name=port] subject="[$NameHotspot] Log $LastPeriod" body="Mail periodica del servizio $NameHotspot, in allegato il registro log del periodo $LastPeriod" file=$LastFile
