It a bit unclear whether you want to make one array with {1,2,3,4} or two-dim array like {{1;2};{3;4}}.
i.e.
:local notificationTeam {{“mateo”;“mateo@example.com”};{“carlo”;“carlo@example.com”}}
vs.
:local notificationTeam {{“sofia@example.com”;“mateo@example.com”},{“beatrice@example.com”;“carlo@example.com”}}
Note: the semi-colon ; appends to ITEM to a array (and the item could be an array). Or, the comma, join TWO LIST together into one (i.e. makes it one-dimensional). So comma and semi-colon will give radically different results.
It’s sometimes hard to see what happens with arrays and the “:put” – they sometime will look the same, when printed, but be internally different… i.e.
:local semi {{"mateo";"mateo@example.com"};{"sofia";"sofia@example.com"}}
:put $semi
# mateo;mateo@example.com;sofia;sofia@example.com
:local comma ({"mateo";"mateo@example.com"},{"sofia";"sofia@example.com"})
:put $comma
# they look the same, but not same when accessing...
:put ($semi->1->1)
# sofia@example.com
:put ($comma->1->1)
# (gets nothing)
# and only the comma version has a 3rd element...
:put ($semi->3)
# (gets nothing)
:put ($comma->3)
# sofia@example.com
# BOTH out put of :put look IDENTICAL
It is confusing.
So viewing the array as JSON often makes the differences more apparent when testing things out:
# if it was {name; email};...
:put [:serialize to=json {{"mateo";"mateo@example.com"};{"sofia";"sofia@example.com"}}]
# [["mateo","mateo@example.com"],["sofia","sofia@example.com"]]
# but the the comma, now a list....within a list
:put [:serialize to=json {{"mateo";"mateo@example.com"},{"sofia";"sofia@example.com"}}]
# [["mateo","mateo@example.com","sofia","sofia@example.com"]]
# so you do need parentheses if you want a one-dim array, without the extra outlist
:put [:serialize to=json ({"mateo";"mateo@example.com"},{"sofia";"sofia@example.com"})]
# ["mateo","mateo@example.com","sofia","sofia@example.com"]
# and you cannot even do this one.
:put [:serialize to=json ({"mateo";"mateo@example.com"};{"sofia";"sofia@example.com"})]
# syntax error (line 1 column 56)
# but it was just two list of emails, always semi-consoles
:put [:serialize to=json ({"igor@example.lv";"mateo@example.com"},{"nadia@example.lv";"sofia@example.com"})]
# ["igor@example.lv","mateo@example.com","nadia@example.lv","sofia@example.com"]
# or
:put [:serialize to=json (("igor@example.lv","mateo@example.com"),("nadia@example.lv","sofia@example.com"))]
# just not...
:put [:serialize to=json (("igor@example.lv","mateo@example.com");("nadia@example.lv","sofia@example.com"))]
# syntax error (line 1 column 45)
