Script not running
I have written four scripts to update my ipsec peers. All of the scripts are ok and working but the problem is the first two of the script can be run from the GUI but the other two doesn’t run from the GUI. The interesting part is they can be run from the terminal by executing the command
/system script run 3
/system script run 4
I want to know is there a limitation how much script can be run from the GUI or is it a bug of the current version ?
maybe check the owner and permissions on each script
I have double checked all the scripts have same permission and attributes
owner=“admin”
policy=reboot,read,write,policy,test,password,sniff,sensitive
