Script not working
I just cannot get this to work.
identify of MT device is: 125-hAP
The script creates the file:
125-hAP_2024-04-07.txt
Including the underline characters at the beginning and end of the file
But the fetch command cannot find the file.
/system
:local cdate [clock get date]
:local yyyy  [:pick $cdate 0  4]
:local MM    [:pick $cdate 5  7]
:local dd    [:pick $cdate 8 10]
:local identitydate "$[identity get name]_$yyyy-$MM-$dd"
/ip/address print file="[$identitydate]"
 /tool fetch upload=yes mode=ftp ascii=no src-path="[$identitydate].txt" dst-path="/mikrotik-backups/$[$identitydate].txt" address=192.168.2.22 port=21 user=mikrotik password=mikrotik
/file remove "[$identitydate]"
Also tried the /tool fetch command with src-path=“$[$identitydate].txt”
As well as without the .txt
Did something change in the scripting over the past several RouterOS updates?
Thanks!
There were some recent builds that “sanitized” the file names. In latest 7.15beta9, it returns to the “old” behavior.
*) console - added “sanitize-names” property under “/console/settings” menu (option for replacing reserved characters with underscores for files, disabled by default);
I don’t know what sanitize means in this context?
I’m sure there was no version that would have given be a health problem (except maybe psychological problems).
Specifically, v7.13 and v7.14 have this changes:
*) console - replace reserved characters in file and script names with underscores;
So sanitize means remove spaces and special characters. The reverted this as a default in 7.15 beta.
Wow, as if the proper usage of “$” and “[” weren’t complicated enough in filenames/variable-names.
And changing things in different versions really does add even more complexity. That’s why they reverted recently I suspect.
