Hi everyone
I have a bit of a problem with a script on a router (RB750G running ROS 6.18).
Below is the script. Basically what it does is pull the TX and RX bytes from a specific interface every hour, convert the data to MB, and then append it to a text file named after each specific date.
# global variables
:global thisdate [/system clock get date]
:global thistime [/system clock get time]
:global datetimestring ([:pick $thisdate 0 3]."-".[:pick $thisdate 4 6] )
# check if file exists, if not create it and set contents to nothing
:if ([:len [/file find name="$datetimestring.txt"]] != 1) do={
/file print file=$datetimestring
:delay 2s;
/file set $datetimestring contents="";
# set variables
:global fileContent;
:global thisHour [:pick $thistime 0 8]
:global txdata [/interface get 5 tx-byte];
:global rxdata [/interface get 5 rx-byte];
# convert to MB
:set txdata (($txdata / 1048576) . " MB")
:set rxdata (($rxdata / 1048576) . " MB")
# get file content
:set fileContent [/file get $datetimestring content];
# append signal to fileContent
:set fileContent ($fileContent . $thisHour . "\tTX: " . $txdata . "\tRX: " . $rxdata);
# re-write file content
/file set $datetimestring contents=($fileContent . "\r\n");
The output of the script is something like this:
09:57:31 TX: 0 MB RX: 451 MB
09:59:02 TX: 0 MB RX: 451 MB
Now when running the script manually it works without any problems, but when I set up a scheduler to run the script every hour (via the command /system script run ) it produces only the following output:
08:00:00 TX: MB RX: MB
09:00:00 TX: MB RX: MB
For some reason it does not insert the variables.
I’ve checked the script multiple times but cannot seem to find a fault. Any help would be much appreciated.
Thank you
