Script Ping (Host To IP) to the variable.
Hi, I do not know how to write a script. Please help.
I would like to use ping to the domain.
Then assign the host IP to a variable.
:local PingResult
:set PingResult [ping www.google.com count=2]
:put $PingResult
:log info $PingResult
result
:log info “2”
How to do that resulted in the IP:
:log info “213.241.87.25”
google is probably not the best example, since it returns multiple ips. It has many servers that can respond.
I used msn because it returned one address.
ping msn.com
:put [/ip dns cache get value-name=address [find name="msn.com"]];
First ping the domain you wish to find.
Then extract the IP from the DNS cache.
Make sure that you use the same exact domain in each command. http://www.msn.com and msn.com are two separate DNS entries. So each command has to match.
there are some ways to do it.
you can use resolve command, something like this
local host1 [resolve google.com]
put $host1 }or
log error $host1 }
