script policy ignored in terminal?
I setup a very simple script to disable simple queue counters - I removed all policy settings, so am expecting the script to not work:
[admin@RB750Gr3] > /system script print
Flags: I - invalid
 0   name="Reset Simple Queue Counters" owner="admin"
     last-started=mar/18/2017 23:36:45 run-count=7
     source=/queue simple reset-counters-all
Running the script using the “Run Script” button in Winbox does what I expect - counters are not reset.
In the log the permission failure is confirmed by the entry:
[admin@RB750Gr3] > /log print follow-only
mar/18 23:56:09 script,error script error: not enough permissions (9)
This is all good.
However, running the script from a winbox terminal window does reset the counters.
[admin@RB750Gr3] > /queue simple print packets
 #    NAME  TARGET                                          PACKETS
 0    Gue.. 10.81.196.31/32                                 14/15
 1    Gue.. 10.81.196.32/32                                 0/0
[admin@RB750Gr3] > /system script run "Reset Simple Queue Counters"
 0    Gue.. 10.81.196.31/32                                 0/0
Why?
