Script: PPPOE Interface Monitoring Script
I wrote this script to help users determine when 1 or more of their PPPOE connections have failed. It is capable of monitoring 1 or more connections, for example a router running multiple ADSL Lines. I chose not to bother with email notifications as it wouldnt be helpful if the device only has 1 internet connection. One could add support for SMS as an option.
The script will log a message as well as control the user-led if it detects a problem. If no PPPOE links are up, the user-led will be off, If all PPPOE links are up, the user-led will be on, and if some are up and some are down it will blink.
Start with creating a user-led entry:
/system leds add leds=user-led type=off
# This script monitors the status of all pppoe connections, and reports their status through the user-led LED and logging.
# It automatically discovers all available pppoe interfaces.
# SynBurst 2016
# Version 1.5
# CONFIGURATION SETTINGS
# 1=ON; 0=OFF
# DEBUG = ALL OUTPUT
# ERROR = ONLY ERRORS
:local debug 0;
:local error 1;
:local prefix PPPOE;
#----STOP HERE----#
:local pppoeinfdown 0;
:local pppoeinfup 0;
:if ($debug = 1) do={:log info "[$prefix] Checking PPPOE Interface(s) Status"; }
:foreach i in=[/interface pppoe-client find] do={
     	/interface pppoe-client monitor $i once do={
     	:local name [/interface pppoe-client get $i name];
     	:if ($status = "connected") do={
			:set pppoeinfup (pppoeinfup +1);
				:log info "[$prefix]$pppoecount $name - $status";
     	:if ($status != "connected" ) do={
			:set pppoeinfdown (pppoeinfdown +1);
			:if (($error = 1)  ||  ($debug = 1)) do={
#NOW CHECK IF ITS ALL UP?
:local pppoetotal ($pppoeinfup + $pppoeinfdown);
:if ($debug = 1) do={ :log info "[$prefix] Total Interfaces Found = $pppoetotal"; }
:if ($pppoeinfup = 0) do={
	/system leds set [find leds=user-led] type=off;
		:log error "[$prefix] ALL PPPOE Interfaces DISCONNECTED";
:if ($pppoeinfdown = 0) do={
	/system leds set [find leds=user-led] type=on;
		:log info "[$prefix] ALL PPPOE Interfaces OK";
:if (($pppoeinfup > 0) && ($pppoeinfdown > 0) && ($pppoeinfdown < $pppoetotal)) do={
		:log warn "[$prefix] $pppoeinfdown PPPOE Interfaces DISCONNECTED";
	:for i from=1 to=25 step=1 do={
		:delay 1000ms;
		:delay 1000ms;
#The END
