I have some scripts on my router to collect bad IP addresses from multiple files
Unfortunately the scripts stop upon error.
The error in all cases is that IP already exists . The IP could have been imported from an earlier file.
The error displayed in the log :
“script error failure already have such entry”
There is no way that I can check every file for duplicated IP, my database has over 7000 black-listed IP.
I seek a solution to ignore the error and continue the script execution.
Thank you for your help.
My router OS version is 6.42.6
this is one of my scripts: They all look the same but the file name is different
:foreach i in=[/ip firewall address-list find ] do={
:if ( [/ip firewall address-list get $i comment] = “IPblacklist1” ) do={
/ip firewall address-list remove $i
/import file-name=IPblacklist1.rsc;
:log info “Removal old IPblacklist1 and add new”;
Thank you all, still having the same error
Failure: already have such entry
I even simplified the code
:do {
/ip firewall address-list remove [/ip firewall address-list find comment=ipblacklist1]
/import file-name=ipblacklist1.rsc;
:log info “Removal old ipblacklist1 and add new”;
} on-error={}
Even for fun I did this code , but I removed few entries to see if it wil work.still the same issue.
:do {
} on-error={}
I appreciate if you could try and let me know what code will work.
