Script stops on first line (no error)
I’m trying to execute this simple script:
/ip add set [/ip add find comment=static] disabled=yes];
/ip r set [/ip r find comment=static] disabled=yes];
/ip dhcp-cl set [/ip dhcp-cl find interface=wan] disabled=no;
It works fine when pasted into a terminal, but when executed from the script it only runs the first line. I’ve tried re ordering the lines and it sill runs the first line and stops.
Mike
There’s a mismatch of closing “]”. You have one “[”, and two “]”. Remove the outer “]”, i.e.
/ip add set [/ip add find comment=static] disabled=yes;
/ip r set [/ip r find comment=static] disabled=yes;
If you try to surround the entire script with “{” and “}”, you’ll see it.
