Hi, I have problem with the clock auto synchronize using NTP or SNTP, it’s not cause of frirewall or other, it’s interne problem mikrotik but everything else works fine, so I need help to set manually the clock updated using any script
Using common ntp servers for time update work reliably. What sort of problems do you see with it?
using cloud update time;
/ip cloud set update-time=yes
Ip cloud is the one example known as not reliable at all…
Sync with your near country ntp server (most of government was provided ntp time server for sync time with computer )
It is working and stable.
Hope it helps.
