I already have an ip binding that is a pass-all rule in case anyone is curious about the place-before command. I am running v3.30.
If I run this from the command line it works. If I remove the place-before it works. If I run the script directly from the command line it works. It worked correctly on v3.23.
then it works in a script. It will fail in the terminal, which at least means I can work around the problem. But frankly just goes to show the lack of coding change control which seems to be commonplace
For anyone else with this problem - here is the reply from MT support:
Try to put following line at the beginning of the script
/ip hotspot ip-binding print
This will save into buffer item numbers ad script will be able to use
place-before=0
Regards,
Maris
It still is a pain in the ass that an upgrade from 3.23->3.30 breaks a previously fully working script.
