script to add ip to list based on log - help needed
Hi folks,
I am trying to make a scrict which adds valid login IPs to a list, and bad requests to another list, but frankly I can’t figure out the Mikrotik language
this is some test code I copied from the forum and adapted
:local tmp [:toarray [/log print  where time>([/system clock get time] - 1h)]];
#for some reason this line echoes the log to the console and nothing is put in array
:foreach i in=$tmp do={
:local logLine  $i ;
#:local put [:find $logLine "dns" -1];
#:put $value
:local put $i;
if I change /log print to /log print as-value it is put in array, but I can’t use the where clause
I would apreciate some help
Here is what I do use to get last 5m log of massages that do contains: negotiation failed
You should be able to modify it to get the data you like
:local loglist [:toarray [/log find  time>([/system clock get time] - 5m) message~"negotiation failed"]]
if the time is 00:00 the “[/system clock get time] - 5m” is negative time value -00:05:00 and do not find the previous day log from 23:55
also, on previous day the date is indicated differently…
Remember? :stuck_out_tongue:
On step 7 is present the final usable script.
step 1: use my RegEx to identify all log lines that containing one IP:
((25[0-5]|(2[0-4]|[01]?[0-9]?)[0-9])\\.){3}(25[0-5]|(2[0-4]|[01]?[0-9]?)[0-9])
on script test on terminal, \ must be added before ? on 6.x version
/log print where message~"((25[0-5]|(2[0-4]|[01]\?[0-9]\?)[0-9])\\.){3}(25[0-5]|(2[0-4]|[01]\?[0-9]\?)[0-9])"
step 2: RegEx can not be used for pick or find…
must be noticed all interested logs like:
SYSTEM: user admin logged in from 100.64.0.33 via winbox
login failure for user admin from 100.64.0.33 via winbox
step 3: ignore the PREFIX and find a pattern for the rules like:
when the string start with “user admin logged in from " and end with " via winbox” put the IP between on ok list
when the string start with “login failure for user admin from " and end with " via winbox” put the IP between on fail list
step 4: how obtain all logs than containing inside a valid IP with a cycle:
/log
:foreach rlog in=[find where message~"((25[0-5]|(2[0-4]|[01]\?[0-9]\?)[0-9])\\.){3}(25[0-5]|(2[0-4]|[01]\?[0-9]\?)[0-9])"] do={
    :local rmess [get $rlog message]
    :put $rmess
step 5: distinguish between actions (igoring the use of complex scripting with array, etc…:
THE SPACE MUST BE CONSIDERED
/log
:global okmsg "user admin logged in from "
:global failmsg "login failure for user admin from "
:global endmsg " via winbox"
    :if (($rmess~$okmsg) and ($rmess~$endmsg)) do={
         :put "OK: $rmess"
    :if (($rmess~$failmsg) and ($rmess~$endmsg)) do={
         :put "FAIL: $rmess"
step 6: with previous founded pattern, extract the IPs
/log
         :put "OK: $rmess"
         :local ipinside [:pick $rmess ([:find $rmess $okmsg -1] + [:len $okmsg]) [:find $rmess $endmsg -1]]
         :put "IP inside is $ipinside"
         :put "FAIL: $rmess"
         :local ipinside [:pick $rmess ([:find $rmess $failmsg -1] + [:len $failmsg]) [:find $rmess $endmsg -1]]
step 7: log the operations, remove the useless “put” for terminal, define the lists and add the IPs, if not already added, for prevent errors…
/log
:global listok "list_success_winbox_attempt"
:global listfail "list_failed_winbox_attempt"
         /ip firewall address-list
         :if ([:len [find where list=$listok and address=$ipinside]] = 0) do={
             add list=$listok address=$ipinside
             :log warning "IP $ipinside added to $listok"
         :if ([:len [find where list=$listfail and address=$ipinside]] = 0) do={
             add list=$listfail address=$ipinside
             :log error "IP $ipinside added to $listfail"
REMEMBER TO REMOVE THE \ BEFORE ? IF USED INSIDE A SCRIPT OR SCHEDULER
Final notices:
The script do not prevent if one IP on whitelist go also on blacklist if sometime fail login.
for do that must be replaced
with
:if ([:len [find where (list=$listfail or list=$listok) and address=$ipinside]] = 0) do={
but if first found the failed login, the successful login do not remove IP from blacklist,
for do that must be added a new line
remove [find where list=$listfail and address=$ipinside]
just before “:log warning”
More complex scripting can be doed if the start / end patterns are putted on one bidimensional array,
with a cycle “foreach” pair of elements on the array for find IPs for more success/fail events at same time.
Another approach is possible, like first finding the start string, than later check if inside is present a valid IP,
But I prefer to find at start only the lines with at least one valid IP inside
for me that is an bug. If you work with time, you do work with time and 00:00 -5m should be 23:55.
Thanks guys. I will test and let you know how it goes. And splunk, thanks, I wrote my own; uses accounting. It has some bugs but its useful to me.
@rextended
Your script gives an error on line 6; that line works by itself but not in the script
line 6 is
:global listfail “list_failed_winbox_attempt”
is impossible that give an error, on any 6 / 7 routeros version…
If the error is “expected end of command (line 6 column 38)” probably you do not copy and paste also the first line of the script: “/log”
@rextended
I have tested your script and work
About this line with condition user is admin
:global failmsg “login failure for user admin from "
and try login from winbox
:global endmsg " via winbox”
How if dynamic user and service (winbox, ssh, ftp) like brute force attack?
replace bot occurencies of admin and winbox with the character asterisk *****
Like this ?
:global failmsg “login failure for user * from "
:global endmsg " via *”
I have tested but not work without error (RoS v 7.10)
