Script to Change All The Ip Port Forward
hy all…
sorry if i make wrong thread. if i wrong just delete my thread.
i need help for script that can be used to change all IP port forward,
please help me and I can not describe one by one my IP because there were too many,
can any 1 help me?
what exactly you want to change and how many rules you have? Maybe you could consider using uPnP, so port forward can be requested dynamically.
hmm…
i see… i must uPnP… let me search about tutorials…
i want to change some port forwarding… like port dota… cause it use many port and when i want to change the port i must change it 1 by 1, or i must remove it manually and add new port, it will be more simple if i can change the port all without remove manually.
at least for me it is not clear what you do, and how many rules you have and where. At first i thought that you are using nat rules to do port forwarding, and a lot of port forwarding usually is done on customer networks where uPnP could solve the problem.
