I am trying to figure out how to make a script to change a bridge port, on netwatch.
I don’t quite understand how to get the number of the port, in a script by it’s name, because when you set something, it wants the number, not the name. This is what I have, but of course it doesn’t work. I don’t understand where you put “()” or “” or “{}” in scripting.
/interface bridge port set [get name interface=ether5] bridge=bridge-Fox-SU
{ } is used for scope. Scope basically tells the OS the context for commands. By default all commands are run at the root context, “/”.
Your example is this:
‘get’ fetches properties into variables, which isn’t what you’re trying to do. You’re looking to use find to return an item to set a property on. Both ‘set’ and ‘find’ are separate commands. You can specify everything as absolute paths:
/interface bridge port set [/interface bridge port find name interface=ether5] bridge=bridge-Fox-SU
Or you can use scope via { } to reset the context of all commands within the scope to “/interface bridge port”:
/interface bridge port { set [find name interface=ether5] bridge=bridge-Fox-SU }
What you have shown me, makes sense, but I can’t get ether of these examples, to work. I have tried them locally on a new terminal session, and also as a script, and ran the script. No errors were displayed. It just doesn’t change the bridge group.
If I just do this:
/interface bridge port set 3 bridge=bridge-Fox-SU it works, but I don’t want to do the that it will be #3
