Script to check wifi clients via capsman
hi at all.
i would like to create a workaround for a “seamless roaming”.
1 capsmann and 2 aps
is there a possibility via scripting to check (on envent or every 10 sec.)
if the singal strengh of the clients from connected ap is under 55 dbm and if so
is there an other ap with better signal, if so, then drop connection (that will force the client to reconnect to next ap).
thx
How would you find out if there was an AP with a better signal?
The rest can easily be done with access-list:
/caps-man access-list
add action=reject disabled=no interface=all signal-range=-120..-80 ssid-regexp=""
-Chris
