Script to control simultaneous user.
Hi all..
as understand now, if we set the profile speed to 1Mbps with shared user = 2.
there is allowed maximum 2 user per account to online concurrently.
is there anywhere can make it.
when user is login with only 1 access, it can having full speed which is 1Mbps speed.
but when the account is have 2 access concurrently, they just can share the 1Mbps speed instead of each getting 1Mbps speed.
thanks.
Short answer: no:
Long answer: not without configuring custom mangle rules and queues for every single client, which doesn’t scale. So: no.
i tot we can have a script and it will check, usually simultaneous user is using same user name, the script can capture that same user name and kick it into the same queue.
but it seem, impossible and will complicated.
then… still is no.
