Script to create multiple Vlans with DHCP
Dear brilliants ,
I need to create 300 Vlans interfaces and link each Vlan with (/ip address , /ip pool ,/ip dhcp-server ,/ip dhcp-server network , /ip hotspot and /ip firewall nat )
example the below script will create only one Vlan:
/interface vlan
add interface=ether1 name=vlan200 vlan-id=200
add address=10.200.0.1/24 interface=vlan200 network=10.200.0.0
add name=Pool200 ranges=10.200.0.2-10.200.0.254
add address-pool=Pool200 disabled=no interface=vlan200 lease-time=1d name=200
add address=10.200.0.0/24 gateway=10.200.0.1
/ip hotspot
add address-pool=none addresses-per-mac=1 disabled=no idle-timeout=1m interface=vlan200 name=vlan200 profile=Hotspot
add action=masquerade chain=srcnat src-address=10.200.0.0/24
The request I need you support for a script to create all 300 Vlans in on command , I am sure there are a brilliant colleagues in this form can have such idea.
Thank you very much in advance .
How does the Script assign IP-Address and Co…?
Is there a Logic* behind it or a File ?
Logic = if vlan100 then IP= 10.1.100.1
Each Access Point has dedicated VLAN, DHCP server and hotspot server. It is users isolation.
