script to disable connections to WAN from a certian IP on a certain criteria
hello
I download from my pc a lot, but this slows down the internet connection on the other connected clients on WIFI, my pc is connected through ethernet not WIFI.
I need a script that does the following.
  • as soon as a client connects to the wireless interface, the script will enable a firewall filter that will stop connections to wan from the pc IP address, which is connected via ethernet.
  • the firewall filter keeps on running unless I disable it manually, so even if all the wireless clients disconnect later, the filter rule will not be disabled
Is possible, you still interested?
