Script to disable radius-mac-authentication
I’m using Freeradius to control the access to my Mikrotik APs. In the radius database I’ve put at the radcheck table all the mac-addresses of my clients. When I put accept as a value, the clients connects immediately, but when I put reject the clients that are connected do not disconnect. I have to disable radius-mac-authentication at the security profile of the wireless interface and enable it again so that the connected clients that are declared as rejected disconnect from the APs and do not reconnect again. Is there any script for doing this automatically. My security profile is named rad-auth.
Thanks in advance
Adi
I think, you should force disconnection of users via CoA packets from RADIUS
Can you tell me how can I do that
try searching forum for ‘radclient’, ‘PoD’, ‘CoA’…
