Hello community - in CAPsMAN you can list all registered clients on all CAP Interfaces. You see MAC of client and Interface.
What you don’t see, is the DHCP name of the client and to which access point it is connected.
I wrote a script to display exact this information. What you will get is:
MAC IP Client AP Signal TX Rate RX Rate Uptime Bytes Packets Interface
FF:FF:FF:11:3E:9C 192.168.12.251 Client01 AccessPoint01 -53 117Mbps 12Mbps 5d01:54:54 68431014,22847922 286257,200633 cap14
FF:FF:FF:11:76:9A 192.168.12.250 Client02 AccessPoint03 -75 16Mbps 12Mbps 1d10:54:53 68123014,54347922 286257,200633 cap12
This is my script:
:global fill do={
# this function fills up a string with a char up to a length - its used to make a tabular view of values
# 3 parameters: #1 string to fill
# #2 length to fill up (or cut down)
# #3 char used to fill up (or as delimiter when cutting)
# if the length of the string is more than the parameter length-1, the string will be cut by length-1 and one char will be appended as delimiter
:local STR $1;
:local LEN $2;
:local CHAR $3;
:if ([:len $STR] >= $LEN) do={
# string has to be cut
:set STR ([:pick $STR 0 ($LEN-1)].$CHAR);
} else {
# string has to be filled up to length
:for i from=1 to=($LEN-[:len $STR]) step=1 do={
:set STR ("$STR" . $CHAR);
:return $STR;
:put ([$fill "MAC" 19 " "].[$fill "IP" 17 " "].[$fill "Client" 12 " "].[$fill "AP" 16 " "].[$fill "Signal" 7 " "].[$fill "TX Rate" 11 " "].[$fill "RX Rate" 11 " "].[$fill "Uptime" 14 " "].[$fill "Bytes" 20 " "].[$fill "Packets" 20 " "]."Interface");
:foreach i in=[/caps-man registration-table find .id] do={
:local locMAC [/caps-man registration-table get $i mac-address];
:local locInt [/caps-man registration-table get $i interface];
:local locSignal [/caps-man registration-table get $i rx-signal];
:local loctxRate [/caps-man registration-table get $i tx-rate];
# reduce to relevant data: "173.3Mbps-20MHz/2S/SGI" --> "173.3Mbps"
:if ([:find $loctxRate "-" -1] > 0) do={ :set loctxRate [:pick $loctxRate 0 [:find $loctxRate "-" -1]];}
:local locrxRate [/caps-man registration-table get $i rx-rate];
:if ([:find $locrxRate "-" -1] > 0) do={ :set locrxRate [:pick $locrxRate 0 [:find $locrxRate "-" -1]];}
:local locUptime [/caps-man registration-table get $i uptime];
:set locUptime [:pick $locUptime 0 [:find $locUptime "." -1]];
:local locBytes [/caps-man registration-table get $i bytes];
:local locPack [/caps-man registration-table get $i packets];
:local locRadMAC [/caps-man interface get [/caps-man interface find name=$locInt] radio-mac];
:local locCAP [/caps-man radio get [/caps-man radio find radio-mac=$locRadMAC] remote-cap-identity];
:local locIP [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] address];
:local locName [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] host-name];
:put ([$fill $locMAC 19 " "].[$fill $locIP 17 " "].[$fill $locName 12 " "].[$fill $locCAP 16 " "].[$fill $locSignal 7 " "].[$fill $loctxRate 11 " "].[$fill $locrxRate 11 " "].[$fill $locUptime 14 " "].[$fill $locBytes 20 " "].[$fill $locPack 20 " "]."$locInt");
Best regards
Bernhard
Hi - I updated my script to also be able to diplay SSID and Clients on Slave Interfaces. When signal strength is below -70db the line is printed red. Also catched some Errors which stopped Script.
Looks like this now:
MAC IP Client AP Signal SSID TX Rate RX Rate Uptime Bytes Packets Interface
98:3B:8F:8B:27:E3 10.22.32.208 Client01 AP01_Floor1 -55 WLAN_Office 173.3Mbps 173.3Mbps 3d08:14:50 2079611693,36712726 5218249,3579269 cap56
E6:B0:C2:D6:D5:73 10.22.32.218 Client05 AP06_Floor4 -68 WLAN_Guest 173.3Mbps 78Mbps 2d03:50:14 15286043,30608002 46680,45932 cap68
Here the Script:
# Script wlan - gives a list of WLAN-clients with DHCP-names and signal strengt collected from 4 tables (caps-man registration-table, caps-man interface, caps-man radio, ip dhcp-server lease)
# v1.0 BV 2021-10-01 - first Version
# v2.0 BV 2021-12-02 - when signal equal or less -70db the line will be printed in red (bad signal)
# v2.1 BV 2022-03-03 - fixed Error with Slave Interfaces (we have to look for the Radio MAC of the Master Interface); inserted SSID
:global fill do={
# 3 parameters:
# #1 string to fill
:local STR $1;
:local LEN $2;
:local CHAR $3;
} else {
:return $STR;
:put ([$fill "MAC" 19 " "].[$fill "IP" 17 " "].[$fill "Client" 12 " "].[$fill "AP" 16 " "].[$fill "Signal" 7 " "].[$fill "SSID" 19 " "].[$fill "TX Rate" 11 " "].[$fill "RX Rate" 11 " "].[$fill "Uptime" 14 " "].[$fill "Bytes" 20 " "].[$fill "Packets" 20 " "]."Interface");
:local locSSID [/caps-man registration-table get $i ssid];
# if we are on a Slave Interface we have to take the Radio MAC from the Master Interface
:local locMasterInt [/caps-man interface get [/caps-man interface find name=$locInt] master-interface];
:local locRadioMAC;
:if ($locMasterInt = "none") do={set locRadioMAC [/caps-man interface get [/caps-man interface find name=$locInt] radio-mac]} else={set locRadioMAC [/caps-man interface get [/caps-man interface find name=$locMasterInt] radio-mac]}
:local locCAP;
:do {set $locCAP [/caps-man radio get [/caps-man radio find radio-mac=$locRadioMAC] remote-cap-identity]} on-error={:put ("ERROR - ".$locMAC." - ".$locCAPMAC)};
# fetch IP and Name from DHCP Server (if present)
:local locIP;
:local locName;
:if ([/ip dhcp-server lease find mac-address=$locMAC]) do={
set $locIP [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] address];
set $locName [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] host-name];
} else={
set $locIP "noIP";
set $locName "noName";
:if ($locSignal <= -70) do={
# bad signal - write line red
:terminal style varname;
:put ([$fill $locMAC 19 " "].[$fill $locIP 17 " "].[$fill $locName 12 " "].[$fill $locCAP 16 " "].[$fill $locSignal 7 " "].[$fill $locSSID 19 " "].[$fill $loctxRate 11 " "].[$fill $locrxRate 11 " "].[$fill $locUptime 14 " "].[$fill $locBytes 20 " "].[$fill $locPack 20 " "]."$locInt");
:terminal style none;
} else={
Hi - I updated the script to catch duplicated DHCP-Entries errors.
# v2.2 BV 2022-03-28 - fixed Error with duplicate entries in DHCP
# v2.3 BV 2022-12-13 - adopting column width (AP, SSID, Bytes, Packets)
:global fill do={
# 3 parameters:
# #1 string to fill
:local STR $1;
:local LEN $2;
:local CHAR $3;
} else {
:return $STR;
:put ([$fill "MAC" 19 " "].[$fill "IP" 17 " "].[$fill "Client" 12 " "].[$fill "AP" 10 " "].[$fill "Signal" 7 " "].[$fill "SSID" 18 " "].[$fill "TX Rate" 11 " "].[$fill "RX Rate" 11 " "].[$fill "Uptime" 14 " "].[$fill "Bytes" 21 " "].[$fill "Packets" 15 " "]."Interface");
:local locRadioMAC;
:local locCAP;
:do {set $locCAP [/caps-man radio get [/caps-man radio find radio-mac=$locRadioMAC] remote-cap-identity]} on-error={:put ("ERROR - ".$locMAC." - ".$locRadioMAC)};
:local locIP;
:local locName;
:do {set $locIP [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] address]} on-error={set $locIP "DCHP-Err"; put ("ERROR with ".$locMAC." - Please check DHCP for duplicate entries")};
:do {set $locName [/ip dhcp-server lease get [/ip dhcp-server lease find mac-address=$locMAC] host-name]} on-error={set $locName "DHCP-Err"};
} else={
set $locIP "noDHCP";
set $locName "noDHCP";
:put ([$fill $locMAC 19 " "].[$fill $locIP 17 " "].[$fill $locName 12 " "].[$fill $locCAP 10 " "].[$fill $locSignal 7 " "].[$fill $locSSID 18 " "].[$fill $loctxRate 11 " "].[$fill $locrxRate 11 " "].[$fill $locUptime 14 " "].[$fill $locBytes 21 " "].[$fill $locPack 15 " "].$locInt);
} else={
Check for errors and some optimization…
See this:
:global fill do={
:local STR $1
:local LEN $2
:local CHAR $3
:set STR "$[:pick $STR 0 ($LEN-1)]$CHAR"
} else={
:set STR "$STR$CHAR"
:return $STR
:put "$[$fill "MAC" 19 " "]$[$fill "IP" 17 " "]$[$fill "Client" 12 " "]$[$fill "AP" 10 " "]$[$fill "Signal" 7 " "]$[$fill "SSID" 18 " "]$[$fill "TX Rate" 11 " "]$[$fill "RX Rate" 11 " "]$[$fill "Uptime" 14 " "]$[$fill "Bytes" 21 " "]$[$fill "Packets" 15 " "]Interface"
:foreach i in=[find] do={
:local locMAC [get $i mac-address]
:local locInt [get $i interface]
:local locSSID [get $i ssid]
:local locSignal [get $i rx-signal]
:local loctxRate [get $i tx-rate]
:if ([:find $loctxRate "-" -1] > 0) do={:set loctxRate [:pick $loctxRate 0 [:find $loctxRate "-" -1]]}
:local locrxRate [get $i rx-rate]
:if ([:find $locrxRate "-" -1] > 0) do={:set locrxRate [:pick $locrxRate 0 [:find $locrxRate "-" -1]]}
:local locUptime [get $i uptime]
:local locBytes [get $i bytes]
:local locPack [get $i packets]
/caps-man interface
:local locMasterInt [get [find where name=$locInt] master-interface]
:local locRadioMAC "00:00:00:00:00:00"
:if ($locMasterInt = "none") do={:set locRadioMAC [get [find where name=$locInt] radio-mac]} else={:set locRadioMAC [get [find where name=$locMasterInt] radio-mac]}
:local locCAP ""
/caps-man radio
:do {:set locCAP [get [find where radio-mac=$locRadioMAC] remote-cap-identity]} on-error={:put "ERROR - $locMAC - $locRadioMAC"}
:local locIP "noDHCP"
:local locName "noDHCP"
:if ([find where mac-address=$locMAC]) do={
:do {:set locIP [get [find where mac-address=$locMAC] address ]} on-error={:set locIP "DCHP-Err"; :put "ERROR with $locMAC - Please check DHCP for duplicate entries"}
:do {:set locName [get [find where mac-address=$locMAC] host-name]} on-error={:set locName "DHCP-Err"}
:if ($locSignal <= -70) do={:terminal style varname} else={:terminal style none}
:put "$[$fill $locMAC 19 " "]$[$fill $locIP 17 " "]$[$fill $locName 12 " "]$[$fill $locCAP 10 " "]$[$fill $locSignal 7 " "]$[$fill $locSSID 18 " "]$[$fill $loctxRate 11 " "]$[$fill $locrxRate 11 " "]$[$fill $locUptime 14 " "]$[$fill $locBytes 21 " "]$[$fill $locPack 15 " "]$locInt"
where will be shown these information?
does anyone have a modified script for the new CAPSMAN for e.g. hAP AX2 where CAPSMAN is in /interface/wifi/registration-table?
