Script to enable and disable a NAT
Hello guys. I’m new to mikrotik and I need some help. I need to check the status of the BGP session named “BGP-01” and if its status is not “established”, I need to activate a NAT rule with comment “NAT GENERAL”. It’s possible?
I tried to adapt some ready-made scripts but I couldn’t… if anyone can help me, I’d appreciate it.
Hey,
Did you managed to find a solution for your use case?
Hi, not yet.
