I would like to record the information you obtain when you issue a '/int wir reg pr" and it shows all of the wireless associations plus thier items like mac, signal strength, etc. I would like to actually write the results to the log file on the router which I then send to a server for diagnosis.
Anybody have any ideas on an easy way to do this. I have not seen a way to get console output to redirect to the log file, I suppose the way to do it would be to write some sort of “foreach” command to take the elements on each line and write them to the log. Any better ideas. Thanks
…Also, is there an easy command that just returns the total number of registered clients as a string. I could at least report that.
