script to make firewall rules
Hi
can someone help with a script that can isolate my 13 ethernet ports from each other in a mesh topology like?
add action=drop chain=forward in-bridge-port=
ether2 out-bridge-port=ether1
thats 1 rule, to make them for 13 ports it will probably be around 156 rules :open_mouth:
So is it possible to make a script for this?
Use split horizon bridging. You will achieve the same result, no firewall, much faster, much less config.
http://wiki.mikrotik.com/wiki/MPLSVPLS#Split_horizon_bridging
Hi. This is not working, it can ping right through it
4 ports bridged to a bridge called Birdge1, I played around on the 4 ports and changed the Horizon value on the bridge, it doesn’t do anything as expected or am I missing something?
ok problem fixed, hehe, I’m a idiot :stuck_out_tongue: ..I used common sense and the forward rule on bridge
