Need some simple scrip to read log on ROS and print warning (IP address in log string ) if in log appers “user logged in, 10.1.1.1”
Script in wiki not working.
Here is an example how to read log entries:
http://wiki.mikrotik.com/wiki/Manual:Scripting-examples#Detect_new_log_entry
Adapt the script for your needs.
i know this script, this line not working
:global currentTime [:totime [/log get [:pick $currentBuf($currentLineCount - 1)] time]];
RoS version 4.4, 4.5, 4.6, 5.1
if you look carefully, line you are quoting and line that is take from the script actually are not the same
line from linked script:
:global currentTime [ :totime [/log get [ :pick $currentBuf ($currentLineCount -1) ] time ] ];
hence, result is not the same.
Here is your error:
Should be:
:global currentTime [:totime [/log get [:pick $currentBuf ($currentLineCount - 1)] time]];
