script to record time of login and logout
hi…
Me again :slight_smile:
My friends :
I need your support to build a script which record time of each login and logout for any clint in my network .
also mail this records periodically to my yahoo account ( really i need this issue to make double check when I’m out of my country ).
Note I use OS v 3.30 and use PPPoE
I appreciate your advice .
Best regards
any update???
need your supervisor please
thanks again…
You don’t need a script for that. You can set up system logging to store pppoe logs in file.
thanks dear ..
but can you tell me please how can i do as like that ?
best regards
In the manual you can find an example how to log to file
http://wiki.mikrotik.com/wiki/Log#Logging_to_file
Also it lists all available topics, in your case you need “pppoe,info”
