Script to remove unflaged sessions
Hey all
I want to remove nonactive session in /user-manager session and I got this code so far but it’s not working and I don’t know how to get it right.
:local Flag
:set Flag [/user-manager session find where flags=""]
:user-manager session print where flags=""
:if([:len $Flag] > 0) do={/user-manager session remove $Flag}
From who, from the junk shop?
Posting random and useless code diverts attention from the underlying problem.
Ask what you want to do, don’t ask to change a code that doesn’t work (?) to do what you want to do…
Sorry that was a typo (I asked and ChatGPT generated that)
I'm looking for a script that can remove inactive sessions from the '/user-manager session' log. With each user login and logout, a log is created, and after a few days, it can grow to hundreds of thousands of entries. I want the script to run periodically, say every 24 hours, to remove the inactive entries. However, I don't want to remove all entries at once, as that would cause users to lose their connection and have to reconnect again hence the script should only remove entries without A (active) flag. How can I achieve this?
I do not have a user-manager v7 to test now, at home, but probably are like the v6, only one instruction:
/user-manager session remove [find where active=no]
If do not work, ask it and I test tomorrow at work with the test device.
That worked man thanks a bunch.
MikroTik script to clean up inactive User Manager sessions while preserving active connections.
_# Script to cleanup inactive User-Manager sessions
Add this script to your scheduler to run every 24 hours\
:local cleanupLog do={
Get current time for logging
:local currentTime [/system clock get time]
:local currentDate [/system clock get date]
Log start of cleanup process
:log info "Starting User-Manager session cleanup at $currentTime on $currentDate"
Counter for removed sessions
:local removedCount 0
Get all sessions without active flag
:foreach session in=[/user-manager session find where active=no] do={
Remove the inactive session
/user-manager session remove $session
:set removedCount ($removedCount + 1)
Log completion with count of removed sessions
:log info "User-Manager session cleanup completed. Removed $removedCount inactive sessions"
Execute the cleanup function
$cleanupLog
Add this to scheduler using:
/system scheduler
add interval=24h name=userman-cleanup on-event="/system script run userman-cleanup" \
start-date=jan/01/2024 start-time=02:00:00_
This script does the following:
  1. Creates a function cleanupLog that:
    o Gets current time and date for logging purposes
    o Logs the start of the cleanup process
    o Counts removed sessions
    o Finds and removes all inactive sessions
    o Logs completion with the number of sessions removed
  2. Uses the RouterOS v7 user-manager commands to safely remove only inactive sessions
  3. Includes detailed logging for monitoring and troubleshooting
  4. Preserves all active sessions (those with the A flag)
To implement this:
  1. Create a new system script:
    /system script add name=userman-cleanup source=
  2. Add it to the scheduler to run every 24 hours (suggested at 2 AM):
    /system scheduler add interval=24h name=userman-cleanup on-event="/system script run userman-cleanup" start-date=jan/01/2024 start-time=02:00:00
  3. You can also run it manually to test:
Enjoy.
Necroposting for nothing.
The least efficient way to do things, a whole page of useless writing to do the instruction I wrote in the previous post.
Hi everyone,
Does removing inactive sessions impact user manager accounting?
:foreach i in=[/user-manager session find where active=no] do { /user-manager session remove $i; }
This remove only inactive sessions
While the one previously posted by rextended, which is much simpler :
did something different? :question:
