script to remove users
Hi all,
i have these scripts
ppp secret disable farqad
ppp secret enable farqad
the script is to disable and enable user named farqad in specific time
the problem is how can i remove him from the active connection when the user disabled ???
please help me with that
thank you all
You have to “kick” the active user.
Try this command:
/ppp active remove [find name=“farqad”]
This will only work if the user is connected to the site where the script is run from.
You could use the :if command to first see if the user is actually online, but the above script should work fine.
G
eve online isk
eq2 plat
final fantasy xi gil
guild wars gold
l2 adena
