Hi
Im using winbox with router hAP ax^2 (arm64), V7.14.3 mikrotik.
I really need a script to reset all mac addresses of a specific user profile and by comment, if possible.
Thnx.
Very clear description.
The same effort you put into asking the question correctly, will be applied by those who answer you.
I Hope so.
you have to ask the question again more clearly, otherwise no one will answer
