Script to reset RB951ui USB port
Hi!
Everytime i reset my RB951ui it will not detect my USB 4G Modem anymore.
I have to physically remove the modem from USB port and reconnect it for the RB951 to detect it again.
Is there a script to mimic this action ?
Another solution is to reset the router every night [emoji13]
Puedes crear un script que contenga la siguiente linea:
/system routerboard usb power-reset duration=10s
Saludos
That’s what i needed ! Thanks !
I’m glad to have helped you
