hello,
how to stop wifi access point managed by capsmanan at certain hours and restart it at another hour
thank you
Access lists https://wiki.mikrotik.com/wiki/Manual:CAPsMAN
You set the interface + time when users can connect to interfaces from particular AP.
In some cases real disable and restart of the interface might be more beneficial, no ?
(at least that’s what I understood being THE major issue with Capsman and Wifi… ref complaints from gotspring)
Simple script and schedule should do the trick but it seems this does not always help.
hello,
I want the wifi points to be cut, I think it is important in the near future.
thank you
But what do you meen “to stop and restart” and “cut”
Do you want to:
a. dissalow acces - ACL let this but WiFi stays visible
b. switch-off WiFi not to be advertised - script wich shutdowns of interfaces is needed
c. switch off the AP - script with shutdown does the trick but there is no easy way to switch it on again remotely.
Use a timer on power socket wall,
or simply disable your phone wifi.
The antenna do not transmit continuosly, transmit if the phone ask for data.
Search on forum various topic are open about that, and already described all.
If you are worried about electromagnetic waves, if you have a mobile phone, maybe in your pocket, you are exposed 100 times more to electromagnetic waves.
Shutdown your phone on the nigth and you solve the problem.
If you are in a palace, turn off the power to the whole building, so you are sure that “at least from here” the radiation is not coming.
I was told a tin foil hat also helps ![]()
